You can back up all files to USB if thats what you want to do ?
Machine Lynx 2100LYB, Fanuc 0i
What is easiest way to backup folder from CNC-MEM to USB ?
From setting I/O device 17 and using File output we are only able to move programs which is on use.
Any help to move folder ?
Thanks,
High light whats within the folder and see if you can paste into usb ------honest i have never tryed but worth a shot
Could you try it from MGI side of things , You should be able to select a Range of Programs in the folder then after pressing the IN/OUT soft key under O List Tab
