Need Help! Puma 5100XLMB gets PS0021 Illegal plane select when polar milling
Results 1 to 7 of 7
Thread: Puma 5100XLMB gets PS0021 Illegal plane select when polar milling
    Default Puma 5100XLMB gets PS0021 Illegal plane select when polar milling
    I am programming for a new Puma 5100XLMB. It has live tooling and a C axis, but no Y axis. I am trying to polar mill a spline with G12.1, which I think the machine should be capable of doing. For some reason, about six lines into the milling code, it gives us a PS0021 Illegal plane select error.
    I could understand if it wouldn't read anything, but it gets a ways into the code before it gives us a problem.
    It will run to this line
    ( 10 MM HIGH FEED MILL )
    G54
    G40G80G99
    N1T0808
    G00G28U0.
    G40
    G13.1
    M35
    G00G28H0.
    G97S4000M3P12
    G00G98Z.25C-11.022M08
    C0.
    X4.5664
    G12.1
    G01X4.4822C-.4365F20.
    Z-.74
    G42X4.4686C-.4292
    G02X4.4896C-.151I.1443J.1339
    G01X4.504C-.1443
    G03X4.5065C.1432Z-.7404I-.1339J.1443
    X3.5288C.3375Z-.7412I-.489J-.5182
    G02X3.4979C.4093Z-.7413I-.0002J.0375
    G03X4.2333C.7857Z-.742I-.2898J.6509
    ?We also tried this format, and it ran to the highlighted line before giving us the error.
    G54
    G40G80G99
    N1T0808
    G00G28U0.
    G40
    G13.1
    M35
    G00G28H0.
    G97S4000M3P12
    C0.
    G0.25
    X5.
    G12.1
    G1C-.4365Z.25F400.
    X4.4822
    Z-.74F7989.
    G42X4.4686C-.4292
    G2X4.4896C-.151R.1968
    G1X4.504C-.1443
    G3X4.5065C.1432Z-.7404R.1968
    X3.5288C.3375Z-.7412R.7125
    G2X3.4979C.4093Z-.7413R.0375
    G3X4.2333C.7857Z-.742R.7125
    X4.0004C1.0473Z-.7424R.1968
    X2.9492C1.0259Z-.7432R.7125
    G2X2.8626C1.0853Z-.7433R.0375
    G3X3.2282C1.5787Z-.744R.7125
    Member DouglasR's Avatar
    Jul 2005
    Default Re: Puma 5100XLMB gets PS0021 Illegal plane select when polar milling
    I don't think the machine can do what you want it to without a Y axis.
    Polar interp is for the milling of non round shapes on the front (snout) of a part.
    It has limited value elsewhere.
    Flies Fast Superman's Avatar
    Dec 2008
    Antarctica
    I don't think cutter comp can be applied to C axis
    Only works on axes defined with G17(XY)/G18(XZ)/G19(YZ)
    Try it by removing the G42
    Apr 2017
    United Kingdom
    Has the machine got Helical Interpolation Option from Fanuc A02B-0339-J819 ?
    About 6 lines into the milling the Z Axis comes into play ?
    Without Helical Interpolation option PS 0021 alarm will occur
    Jul 2005
    Quote Originally Posted by Dale123 View Post
    Helical is standard from Doosan, but the Polar isn't made for that.
    Apr 2017
    United Kingdom
    Quote Originally Posted by DouglasR View Post
    Doosan supply as standard on Y Axis lathes but it isn't standard in the UK on M Models . It's either specified on order or a Fanuc retrofit.
  7. #7
    Member Zerok666's Avatar
    Feb 2019
    I do not see a plane called out in your code. Try adding a G17 to line G40G80G99.
