- Need Help!- DEAWOO PUMA 200
DEAWOO PUMA 200
Hi, I'm New to these forums' so if I'm in the incorrect place Please tell me Thank You,
Ok I have a puma 200 got coolants in hydraulics " 2005 alarm" - I clean out, put new hyd fluids in, started up for second
then made a crazy sound i e-stopped it, now i get a 2001 alarm (says e-stop on or over travel occurred) now hyd's wont even try to start.
need to clear 2001 Alarm before? or
Thank's
David
Re: DEAWOO PUMA 200
You may have a wiped out pump.
But, check breakers and fuses in the rear cabinet first.
- You may not post replies
- You may not edit your posts
Forum Rules
