- Daewoo Puma 8 Alarm code 16 & 17
I have a 1996 Daewoo Puma 8S with the Fanuc 0T-C control On the machine control panel (not the Fanuc control) alarm I am getting a code 16 and 17. I have tried googling a solution.
I know it's likely time for a new lathe however this machine makes one simple part, it's made this same part for the last 10 - 11 years and still makes good parts.
Thank you,
Tyler
Re: Daewoo Puma 8 Alarm code 16 & 17
WHats the status of drives ? Is there any alarm ? Please reply
I didn't see any alarms on the drives, I will double check when I return to the shop. I believe they were 0 -- 0 on the three drives..
- You may not post replies
- You may not edit your posts
Forum Rules
