- Need help
Need help
I Want run program from usb in Doosan dfv mill.
Can someone help me out ?
Re: Need help
Can't be done . You can run from PCMCIA Compact Flash card or drip feed into the control .
Re: Need help
Fanuc will not allow it. It must be run from internal memory, PC card, data server, or LAN/RS-232 drip feed.
- Need help
- You may not post replies
- You may not edit your posts
Forum Rules
