Problem Daewoo Puma 230M - X axis overload
Results 1 to 3 of 3
Thread: Daewoo Puma 230M - X axis overload
    Member Mtmont88's Avatar
    Oct 2021
    Default Daewoo Puma 230M - X axis overload
    Hello!
    We moved our Daewoo Puma into new place. Now when we start it up, the Alarm shows 409 - x axis overload.
    Overload is like 180% , but we dont know why. Machine didnt fall or anything when we move it.
    What can cause that problem? We checked spindle on X axis and it's ok.
    Best regards,
    Sribar
    Jul 2007
    australia
    Default Re: Daewoo Puma 230M - X axis overload
    Check the terminals on the motor and make sure it hasn't come loose. I had the same issue and was told it was a faulty drive. Turns out the terminals were loose. Saved 7K on a new board.
    Oct 2021
    Thank you for answer. Can you tell me where is that terminal on the motor?
    Sribar
