Need Help! Fanuc 21i alarm 2103 must be command maintenance ATC 1 cycle
Results 1 to 11 of 11
Thread: Fanuc 21i alarm 2103 must be command maintenance ATC 1 cycle
    Apr 2011
    Default Fanuc 21i alarm 2103 must be command maintenance ATC 1 cycle
    Vertical 5025 machining center
    forgot I had to change spindle location for tool change after changing spindle bearings
    of course it faulted because keys not lined up
    I thought I did everything right to get out of it but still get alarm
    tool arm appears put back, all looks good but get alarm, x and y move but can't move z axis . Z can not be referenced
    Any help to clear the alarm would be appreciated.
    I did read a bulletin about it and it said change Keep Relay K12-B4 parameter 1 to 0 but mine is zero if I am looking in the correct spot.
    Apr 2011
    Default Re: Fanuc 21i alarm 2103 must be command maintenance ATC 1 cycle
    can you post the ladder file?
    Apr 2011
    Quote Originally Posted by drdos View Post
    LOL I can try, its been 15 years since I got into ladder.
    Let me see If I can figure out how
    Apr 2011
    I found the I/O softkey (I assume that is what you wanted) and was able to save to my PCMCIA card but no idea how to post it here or even read it on my PC since its .000 extension.
    Apr 2011
    I figures it out, thanks
    I had to change keep relay 64.4
    Sep 2007
    the netherlands
    hi,
    in maintenance mode you can move though the cycle step by step .
    M39 in the MDI
    Move handle to jog
    Go around back and index carousel until it stops moving
    Go back around front
    M19
    M41
    M40
    "copied text from internet" but i can take a photo from my manual
    then if all is well the machine makes 1 tool cycle
    greetings bertus
  7. #7
    Member dhardt's Avatar
    Feb 2013
    Quote Originally Posted by RaceFan View Post
    Please note: on some machines this keep relay is K12.4, others it is K64.4
    This relay can only correct the issue if the CAHP.M (changer arm home position. monitor) is a 1 as well as THOMEI.M (tool home indicator. monitor) being a 1 if it is present.
    As these are LADDER issues....they are changeable at any time by alteration or upload of a ladder change. (these potential solutions are not "set in stone" and can be changed to something different)
    DO NOT RANDOMLY change Keep Relays without fully understanding what it will do, or you could cause permanent damage to your machine.
    No longer with Doosan Machine Tools America
    darrylhardt@gmail.com
  8. #8
    Feb 2013
    Quote Originally Posted by bertus.nl View Post
    hi,
    M39 in the MDI
    Move handle to jog
    M19
    M41
    M40
    greetings bertus
    M250 would put it into MAINTENANCE MODE
  9. #9
    Sep 2007
    the netherlands
    No
    M39 puts the toolchanger in maintenance mode if you have problems.
    with the buttons of the toolcarrosel you can run forward and back trough the cycle .
    the keeprelay is for telling the machine it is on the home position
    greetings bertus
  10. #10
    Apr 2011
    hi,
    M39 in the MDI
    Move handle to jog
    M19
    M41
    M40
    greetings bertus
    Ah ha, "until it stops moving" . I used the M39 several times in the past vut only to move the arm out of the way. And yes when I tried to resolve this issue, the carousel moved so I stopped and figured it was not working. I needed to rotate carousel a full rotation and then it would stop?
  11. #11
    Apr 2011
    Quote Originally Posted by dhardt View Post
    Yes I agree. I looked through the ladder and figured out which latch was needed to clear the fault. I have a little experience with ladders from my G&L repair days 30 years ago lol. It just took a bit to search and find because I don't know how Fanuc works.
    Changer arm was home but can I search for the CAHP.M ? Or better yet, how can I search for it?
