Need Help! Puma 2600Y II Fanuc 0i-TF Pulse handle
Results 1 to 3 of 3
Thread: Puma 2600Y II Fanuc 0i-TF Pulse handle
    Sep 2006
    Finland
    Default Puma 2600Y II Fanuc 0i-TF Pulse handle
    Pulse wheel works ok to - direction, but when rotating to + direction movement is not smooth, machine stops suddenly and then starts to move again.
    Position is ok but movement is not smooth.
    There is 4 wire's coming back to pulse wheel, they seem to be ok when shaking.
    Wire's are marked A,B,0V, +V
    What could be reason....new pulse wheel or some card problem ?
    Thanks,
    GB
    Member dhardt's Avatar
    Feb 2013
    Default Re: Puma 2600Y II Fanuc 0i-TF Pulse handle
    Confirm pinout and voltages though the MPG by using the appropriate drawing for B31 or B32 setup
    If further assistance is needed, call my cell 973-803-9479
    Attached Files Attached Files
    Doosan Service Technician
    darryl.hardt@doosanmt.com O:973-618-2461 M:973-803-9479
    Sep 2006
    Finland
    MPG was faulty, new one was not expensive and machine rocks again.
    Thanks for help,
    GB
