Problem Puma 400XLM M31 not working.
Results 1 to 5 of 5
Thread: Puma 400XLM M31 not working.
    Default Puma 400XLM M31 not working.
    Hi.
    I work on a Puma 400XLM with Fanuc 21iT control,
    To set up and move around the tailstock and steady rest I have written macros assigned to M codes, but these will only run when the chuck is clamped.
    I would like to be able to run these from MDI with an unclamped chuck.
    Any pointers to how I could get this working or how I should incorporate M31 in the macro to get it to work?
    Kind regards.
    Nov 2007
    Canada and Nothern ireland
    Default Re: Puma 400XLM M31 not working.
    The Answer is in the Keep Replays but use at own risk and have a great day
    Sep 2007
    the netherlands
    hi
    try starting with a closed chuck(with a dummy workpiece ) then M31 .
    O0001;
    M31;
    M69: (OPEN CHUCK)
    G461 V5; (GET TAILSTOCK ,)
    M32; (CANCEL SAFETY OVERRIDE)
    ; (youre program text)
    G460; (RETURN TAILSTOCK BACK TO REF POINT Z)
    M30
    Programs O9013 / O9014 are programmed by Doosan
    O9013(G461 AUTO TAIL STOCK)
    (HK 08-09-2016)
    (SET PARA.6053 = 461)
    #3003=1(SINGLE BLOCK DISABLED)
    #20=#4120(GET TOOL NO.)
    #1101=1
    G28U0.
    T0000(OFFSET CANCEL)
    M05P11
    M79(TAIL STOCK QUILL RETRACT)
    G53G00Z[#500]
    (MOVING TO PTS POS.)
    M46(BAR INJECT)
    #21=#4005(GET MODAL)
    #100=#3005AND4(INCH/METRIX)
    IF[#100EQ4]THEN#23=80(INCH)
    IF[#100EQ0]THEN#23=1000(METRIX)
    #1=#4005
    IF[#1EQ98]GOTO100(G98 MODE CHECK)
    IF[#1EQ99]GOTO100(G99 MODE CHECK)
    GOTO101
    N100G98G1W2.5F200
    G53Z795F1000 (Z VALUE LENGTH OF MACHINE )
    N101
    G[#21]
    (MOVING WORKPIECE CORD.ZERO POS.)
    M47(BAR RETRACT)
    T[#20](RETURN OFFSET)
    #1101=0
    #500=#5022(SAVING PTS POSITION)
    #3003=0
    M99
    O9014(G460 AUTO TAIL STOCK)
    (VER5.2,2A.M.Y TYPE,2011-08-17)
    (SET PARA.6054 = 460)
    #1101=1
    G28U0.
    M05P11
    G53G00Z[#500]
    M46(BAR INJECT)
    IF[#100EQ0]THEN#23=2000(METRIX)
    #1=#4005
    G94G01Z[#22]F[#23](G CODE SYSTEM B)
    GOTO101
    N100G98G01Z[#22]F[#23](G CODE SYSTEM A)
    N101
    G[#21]
    M47(BAR RETRACT)
    #1101=0
    #3003=0
    M99
    This is wath i juse on my machines
    trying is at youre owne risk
    hoop it works for you
    greetings Bertus.nl
    Quote Originally Posted by lshingleton View Post
    I've looked it up and I have found the relevant Keep Relays and that would indeed sound like a solution. Only that leaves the possibility open that the program gets started with unclamped workpieces unless the operator is very careful and observant. I don't know if I trust my colleagues enough for that, and I don't want to get sacked when they **** it up for changes I made.
    @Bertus.nl Yes I have gotten M31 to work from a clamped situation, but that entirely defeats the purpose for my use. Our parts are the full range of the chuck and the full length range of the machine.
    I would like to be able the re setup the machine completely without needing to clamp or have clamped something of the current diameter.
    I have attached the description of the M code in the reference book.
    Attached Thumbnails Attached Thumbnails Puma 400XLM M31 not working.-img_20210401_003727-jpg
    Nov 2007
    Yes we ran many Automated machines this way and the real issue is the machine looking for the switches but if they are removed via this but it all comes with risk
    The ones i did it on was using the tail stock so the use of the Tail stock sensor made sure the part had been seated
    Good luck
