i receive parameters and pmc parameters for similar machine 8s i reload but still have problem machine not works
when i turn on machine shows
PLC loading data
1 load from IO
3 run
4 run without pmc
i put run but shows LADDER NOT EXIST any IDEA???
hi please help need parameters for lathe Daewoo Puma 8s 1995 year Fanuc OTC turret 10 tools
please helps
PLC loading data
1 load from IO
3 run
4 run without pmc
On that controller the ladder is typically burned on EPROM's. However, you could have a development board that is used till the ladder has been proven out then you burn the ladder to EPROM's. Looks like they didn't do that so now you don't have a ladder. Can you post a pic of the controller? You probably have PMC-M which means that the EPROM's would be on that board. If you have PMC-L then the EPROM's would be located on the Memory board marked 0E1 & 0E2. The other possibility is that your machine has the ladder PMC type set incorrectly. Post the parameters as well. Verify that the backup file that you used for the parameters contain the 900's parameters. These are NOT saved if whoever did the saving didn't press and hold EOB when saving them.
[IMG]www.zapodaj.net/2a842194a341d.jpg.html[/IMG]
[IMG]www.zapodaj.net/60f5d316bf06c.jpg.html[/IMG]
[IMG]www.zapodaj.net/b74888758ec0b.jpg.html[/IMG]
i have parameter from similar machine,i load everything from similar machine and if i try press 3 run show ladder not exist i dont know how to resolve this :/
i try change 905 parameter also bit by bit and nothing,this parameter read PMC
N0900 P 00111000
N0901 P 11100001
N0902 P 00000100
N0903 P 10001000
N0904 P 00000000
N0905 P 00000001
N0906 P 00100000
N0907 P 01010000
N0908 P 00000000
N0909 P 00100001
N0910 P 00000000
N0911 P 00000000
N0912 P 00000000
N0913 P 00000000
N0914 P 00000000
N0915 P 00000000
N0916 P 00000000
N0917 P 00000010
N0918 P 00000000
N0919 P 00000000
N0920 P 00000000
N0921 P 00000000
N0922 P 00000000
N0923 P 00000000
N0924 P 00000000
N0925 P 00000000
N0926 P 00000000
couple my parameters 900
Looks like you have PMC-L which means you have to have EPROMs on the Memory board at 0E1 & 0E2. Your pics didn't come through
These attachments are not working either. Do you have a backup of the ladder? Most people don't. May have to see if Daewoo can provide.
Doosan said cant help machine is too old
machine works i change 2 eproms for another and change mem card for another
now read pmc and show ladder
axis works,spindle works but i have probelm with turret maybe that why becouse input parameters from lathe puma 8s wiTH 12 turret tools i have 10 on own machine turret tools
i find in on web diagnostic D443 parameter on my machne is all 00000000
help how change this
error on Daewoo display is 27 number something with time exceeded changing tools(key works i check in diagnostic )turret not index any tools ,valves solenoid on turret led is off there is 2 valves and 4 position, both not shine like pmc not control this valves
ok let you know tommorow
