At 72 Celsius the kluber will start to break down.
But thermal expansion on damaged bearings causes more damage, causes more heat, causes more expansion, causes more damage...
The sensors in an integrated motor, monitor the potential overheat of the stator, not the bearings.
If the machine is equipped with bearing probes they will note that it is hot, but not guaranteed to stop before a catastrophic issue.
