What is the serial number?
Hi all
can any one tell me the function of the button with key selector in the picture please?
machine is doosan puma lathe with fanuc 21i TB
Doosan Service Technician
darryl.hardt@doosanmt.com O:973-618-2461 M:973-803-9479
There is an Optional Enabling Keyswitch on some CE certified controls.
It might be that...See attached.
To confirm: Find that section of your electrical manual, get the -SK## from the schematic, open the operation panel and locate the backside of the keyswitch. It will be labeled with similar numbers.
thank you for your reply dhardt:
machine serial number is P35L3149
i find this attached drawing in the electrical Circuit Diagram
i need to know what this key does in operation for example, is it for program restart ?or maybe for spindle ?
if you have similar operation control panel maybe you can help,
i didnt find in the manuals any thing talk about this symbol
thanx again for your reply
Looks like the Door Open switch . With it at "1" it allows you to handwheel the Axes for setting up with the door open .. If its never used them I assume you have overridden the safety interlocks.
of course I override the safety interlock its OCTG lathe
any way i will try with the door after tomorrow and will tell you the result guys
thanx for your reply Dale123
