Tool Setter Calibration - Lynx 2100 LSYB w/ Oi-TF Plus Control
Results 1 to 3 of 3
Thread: Tool Setter Calibration - Lynx 2100 LSYB w/ Oi-TF Plus Control
    Member MetalDawg's Avatar
    May 2015
    Default Tool Setter Calibration - Lynx 2100 LSYB w/ Oi-TF Plus Control
    I have a new 2020 Lynx 2100 LSYB that has the new Oi-TF Plus control.
    Does anyone have instructions on how to calibrate the tool setter? I would call Ellison, but it is the day before thanksgiving and no one is answering the phone.
    There is a ten year old thread on this subject that talks about what numbers go in which parameters, but I am not confident those parameter addresses are the same for this new control.
    Thank You!
    Member dhardt's Avatar
    Feb 2013
    Default Re: Tool Setter Calibration - Lynx 2100 LSYB w/ Oi-TF Plus Control
    I just called and they picked up on 2 rings...
    Unless Fanuc has changed their parameter, or the write-up is not for a Fanuc, it will work.
    Your instruction Manual that came with the machine has replacement process, as well.
    The attached is the Installation Manual for a Lynx 220. The process is on page 28
    Attached Thumbnails Attached Thumbnails Tool Setter Calibration - Lynx 2100 LSYB w/ Oi-TF Plus Control-lynx220_l220mise951-pdf
    No longer with Doosan Machine Tools America
    darrylhardt@gmail.com
    May 2015
    Thank you very much for the reply. About 30 minutes after I made the post I made another call, and they did answer. They put in a case number for someone to get back with me. I might have called too early since I called right at 8:30am local. I looked in the instruction manual, but I did not see it. I will look again though. I really appreciate your help.
    Thank You!
    Darryl
