Need Help! PUMA240 Fanuc 0i-TB Display dead
Results 1 to 5 of 5
Thread: PUMA240 Fanuc 0i-TB Display dead
    Sep 2006
    Finland
    Default PUMA240 Fanuc 0i-TB Display dead
    Machine PUMA 240MC-03
    Fanuc Oi-TB
    After weekend machinde display stays blank. Machine seems to work OK but display dead.
    Small fuse checked and incoming voltage 24vdc ok.
    LCD/MDI unit A02B-0299-C081#T
    Any idea where problem could be or is it just buy new LCD ?
    Thanks,
    GB
    Member dhardt's Avatar
    Feb 2013
    Quote Originally Posted by Green Button View Post
    Fanuc Oi-TB
    Thanks,
    GB
    Recommendation: check cables, connections, and power supply.
    If no issue found, call Fanuc 1-888-fanuc us
    Sep 2006
    Finland
    Default Re: PUMA240 Fanuc 0i-TB Display dead
    Thanks, i will check these
    May 2016
    United Kingdom
    Have you checked where the lcd connects onto the board ?
    Does the machine move without the screen on ?
    Sep 2006
    Finland
    Machine works just fine and moves ok. It's just bit difficult to drive machine "at night"
    I try to look all connections but could not find anything loose.
    I have to contact Fanuc people to check, they will change LED display.
    Faulty part was propably some card behind display.
