- Im a dumb student.....
Hello everybody i hope all is well, Let me just briefly explain my situation, im currently doing an internship at a plastic manufacturing company and they have many HAAS machines and im well able to use them, but they recently purchased a doosan Puma 280LM with a Fanuc oi -TC controller, so far i have been able to send jobs too it over Ethernet (I created a virtual com port)
ANYWAYS My question is very ambiguous all im trying to do is start the job and setup tool changing but im LOST, when i try starting it it says IMPERFECT WORD must be changed..... Any help would be fantastic, and also have no clue about the tool calibrator, when i push it down it just goes backup...
Re: Im a dumb student.....
Imperfect word means the Fanuc cnc doesn't recognize what you've fed it.
Example? Pictures? Code?
I used to work for Doosan, and I have the training manuals I wrote, if you'd like.
hi
when in manual guide the softkey start is pushed [softkey]
you can select start program , start new operation , ect
when you select start program
something like apears
G54
G40 G80 G90
G50 S2500
T?
G? (G96/G97) S? M03 P11
every time you see a "?" sign, you change the word
So T? for example
first select the word so that T? becomes yellow
then you type 0101 for tool nr 1 offset nr 1, and the press the alter key
then it says T0101
same is for all the other "?" signs
hope this helps
https://manualzz.com/doc/23340305/ma...rning-examples
greetings bertus
hi
try cleaning the base of the arm .
or push the button ones
bring the toolpoint close to the thing with the 4 thingies ,and then move the tool in jog mode to the sensor
this sould go slow and if made contact it will auto retract and make the change in the offset for that tool
greetings bertus
Why are you not in the NC programming screen ?
Yes on that machine there is another NC screen right ?
You are on the simulation side of things ?
hi
No this is the EDIT "side" like it say's on the top rigth corner of the screen in manual guide I
greeting, Bertus.nl
I think it is on the System Screen i just cant remember but it says NC and it is white with black lettering ---------Only time i ever seen or used that side was for simulation and its blue and grey ---------------These are the Fanuc quick edit screens and stuff and really are an other attempt at conversational programing --------Good luck
- You may not post replies
- You may not edit your posts
Forum Rules
