Need help regarding steady rest, XLM480
Results 1 to 8 of 8
Thread: Need help regarding steady rest, XLM480
    Member jamshedjadun's Avatar
    May 2020
    Default Need help regarding steady rest, XLM480
    The machine spindle doesnt rotate with steady rest in clamped position. All pressures are normal. Even of the rrst is moved away from workpiece n clapmed(without the piece), the spindle takes a jerk but doesn't rotate/operate.
    Note: there's no warning/error message shown.
    Sent from my JSN-L22 using Tapatalk
    Member dhardt's Avatar
    Feb 2013
    Default Re: Need help regarding steady rest, XLM480
    What is the machine's serial number? (found on the placard, located near the main power switch)
    What is the Electrical Hardware version? (found on the placard, located near the main power switch)
    What is the ladder version?
    Press the <SYSTEM> hard key
    Press the <PMC> softkey (depending on Fanuc model)
    Press the <PMCPRM> or <PMCCONFIG> (depending on Fanuc model)
    Press the <TITLE> softkey
    There is a field: PROGRAM DRAWING NUMBER (it is in the middle of the page)
    It contains a LONG alphanumeric sequence, separated by a comma or colon...and then another alphanumeric sequence
    I need the WHOLE code...everything in that field.
    From this information, I can see why the machine does anything and everything related to IO
    No longer with Doosan Machine Tools America
    darrylhardt@gmail.com
    Feb 2013
    ...And I assume that you meant that the MAIN SPINDLE doesn't turn...(and not the Milling Spindle)
    480XLM (Puma 480mm swing, Xtra Long body, Milling spindle included)
    May 2020
    Quote Originally Posted by dhardt View Post
    Here is ur requested info.
    Serial no.: ML0149-000137
    Electrical hardware version: P24MH31UA02
    Program drawing no.: P24MDE03_01
    PMC program no.: E03
    I hope that helps.
    May 2020
    Yes. The main spindle.
    Picture for reference is attached.
    Feb 2013
    Are you trying to rotate the chuck without any stock in it?
    If yes, do you have the proximity switches for chuck open and over-stroke held on or off with the keep relay?
  7. #7
    Feb 2013
    Do you have Polygon Mode on?
    Is the Q-setter seen as up? ...and not down? ...and none of the read heads are activated?
  8. #8
    Feb 2013
    Is the Steady rest body clam/unclamp confirm reading correctly?
    SYMBOL: SRBU.M (Might be address of: X12.1)
    The closest ladder I could find to yours was P24MDC08 so addresses can be different, but symbols are usually the same.
