Is the drop guard that overlaps the installed chip pan in the down position?
Is the machine installed to the correct height so the guard can be dropped to overlap correctly?
I have a "new" (to me) a Doosan 3016 and I do have the manuals but nowhere in my manuals do they show the configuration of the chip tray / coolant tank and in setting this one up I feel like either I did it wrong or am missing a piece (or wtf with the design ??).
Basically: any time you run the coolant, as it leaves the machine and drains out to hit the tank there is excessive splashing as it hits the chip tray. Now, ok some splashing is normal. But this is excessive - to the point where theres a huge puddle to the side of the machine if you run coolant on for any decent length of time - and no it isn't leaking. The puddle is from overspray / splashing as it hits the tray - and a few drops bounce out but it really adds up fast. For now I've just rigged up some "walls" but I'm thinking I've set it up wrong as no one else I see in pictures has any "walls" set up nor do they have big puddles beside their machine...the tray has its own "walls" along the front edge of the machine but its as if they needed to be extended and wrap around...
and what are the two small "cutouts" at the top of the splash wall (one on either side) for ? it looks like some sort of contraption (that I might not have) would go into there...
thanks for any tips
No longer with Doosan Machine Tools America
darrylhardt@gmail.com
Hey sorry for the delayed response... apologie I'm not sure what you mean by "drop guard"... but it sounds like thats what I'm needing ! There is a chip pan (lot of perforated holes runs across the enitre front tank). Theres a perforated screen that slides in at like a 30deg angle underneath it. The machine is at the specified height, with approx a ~1 inch gap from the bottom front edge of the machine to the top of the front edge of the coolant tank / chip tray. What I've done is just laid umhw / rubber around the sides to try to contain the mess but I'm sure I'm missing something here...
I'm on vacation this week. I teach a class as soon as I return. Please check your parts book for the appropriate replacement guard.
If you don't have a part book, provide the serial number to your local dealer and they can assist you in finding the part or getting a replacement book.
I have parts book. And the manuals. There is zero mention of drop guard, or anything similar. Its ok.. In any case, was hoping someone else can shed light on why this is going on, or if its normal. My nearest rep is 4 hours away so not keen on hiring him a minimum of 9 hours just to tell me its "normal"...
hi, you are lucky a new machine arround here is leaking big time .... about yours, if you wil share a few photos, i may suggest some 'walls'But this is excessive - to the point where theres a huge puddle to the side of the machine if you run coolant on for any decent length of time - and no it isn't leaking.
send him a video / kindlyMy nearest rep is 4 hours away so not keen on hiring him a minimum of 9 hours just to tell me its "normal"...
we are merely at the start of " Internet of Things / Industrial Revolution 4.0 " era : a mix of AI, plastics, human estrangement, powerful non-state actors ...
Thx Daryl i will send you a pic. I still cant figure out what you're showing me in that pic, so I'd say "no". The machine isn't 'leaking', its splashing out from the top...
hy, the ijfel tower is leaking everywhere ... especialy when there is a rainy cloud above it regardles of picture size
