Part of solution has been found in the following post:
https://www.cnczone.com/forums/daewo...-machines.html
Let me re-post two docs found on it:
I have the spindel's encoder belt broken and I need to disassemble the upper part of the spindle in order tu put the new belt in place.
I have only the general parts drawings includes in the user manual. I need more detailed drawings of spindle assembly before to start the job.
Is anyone could provide me such detail and also some advises?
It would be greatfull!
The CNC is a MYNX-500, SN: AV5E 0414
Thank you in advance!
- Need Help!- Daewoo Mynx 500 parameters help
- Problem- Daewoo ACE-V35 OMC spindle drive belt
- Need Help!- atc daewoo mynx 530
- Problem- Daewoo 4020 Mill Spindle Belt Breaking
- spindle encoder belt
If you have any advice it's welcome !
For this type of issue, contact Darryl Hardt in service. 973-618-2461
Thanks Douglas!
You literally have the best document for the best information, linked in the post that you did at 0741 today...
No longer with Doosan Machine Tools America
darrylhardt@gmail.com
Hi Darryl, thank you for your confirmation.
Let's start the job ;o)
