- 1997 Daewoo LYNX 200A lost parameters. FANUC 21T
Activation process
Hello everyone, I bought a Lynx and had a cpu problem. Bought a new board and the parameters are completely lost. I can not see the ladder either. Any advice on how to get them or buy them? Thanks in advance.
Regards
Ernie
Re: 1997 Daewoo LYNX 200A lost parameters. FANUC 21T
This is, I think the 18th time I've seen this type of problem here.
Have you contacted Doosan or your distributor?
Your ladder won't get displayed till you set the PMC option bit that tells the control which PMC type you are using. I don't have a backup that will work with your machine.
Banned
Contact to support@quanutmautomation.com They will help you with parameters
- You may not post replies
- You may not edit your posts
Forum Rules
