There are a few things here.
You're trying to access the main spindle from the lower path. If you "really" want to do that, you need an M264 "other pulse coder" command on a line by itself BEFORE the commands and then a M265 afterwards.
Hello!
I need help with the issue by rigid tapping with lower turret on left spindle.
I get alarm for RIGID MODE DI SIGNAL OFF.
I don't know where is the problemm in programm.If I enter M29 S300 P21 or P22 cycle work normaly.Only with the P11 doesn't want to work.
Can anybody help me.
Regards
Janko
Hmm..
M264 Has to be on a line by itself, before any spindle commands.
the rigid tap line should read G97S250M29P11 then the G84 Z-.5F.05, G80, then M265.
