- Problem- turret index issue
*Registered User*
turret index issue
Doosan lynx 300M
Fanuc i series
Every time I try and index counter clockwise, it goes 2 tool locations instead of 1, then errors with a 2119 tool change timeout.
Proximity sensor seems to be working.
Tools are fairly balanced, run for 2 weeks before this issue turned up.
If I go clockwise, it works normally.
Running machine with M180's Infront of tool changes to keep it running but...
Any ideas why counter clockwise is being weird?
Re: turret index issue
i have a similar problem on my puma 200 and was a small relay , i switched for the one that control the light and solve the problem but not light , i replace all of them, no more problems, was not to expensive
- You may not post replies
- You may not edit your posts
Forum Rules
