Spare M code - M92 - DMV3016d
Results 1 to 5 of 5
Thread: Spare M code - M92 - DMV3016d
    Member avongil's Avatar
    Sep 2008
    Default Spare M code - M92 - DMV3016d
    I want to activate an air blast via an M code on a 2003 DMV3016d. I threw a relay in and connected it to L92. It does work, but It seems like it is waiting for an M-Fin signal. Also, I need a way to turn it off! I cannot find any documentation other than the wiring diagram. Any help would be appreciated.
    Thanks.
    Member dhardt's Avatar
    Feb 2013
    Default Re: Spare M code - M92 - DMV3016d
    What is the machine's serial number? (found on the placard, located near the main power switch)
    What is the Electrical Hardware version? (found on the placard, located near the main power switch)
    What is the ladder version?
    Press the <SYSTEM> hard key
    Press the <PMC> softkey (depending on Fanuc model)
    Press the <PMCPRM> or <PMCCONFIG> (depending on Fanuc model)
    Press the <TITLE> softkey
    There is a field: PROGRAM DRAWING NUMBER (it is in the middle of the page)
    It contains a LONG alphanumeric sequence, separated by a comma or colon...and then another alphanumeric sequence
    I need the WHOLE code...everything in that field.
    From this information, I can see why the machine does anything and everything related to IO
    No longer with Doosan Machine Tools America
    darrylhardt@gmail.com
    Sep 2008
    I have placed pictures of the screen here:
    https://photos.app.goo.gl/U6h89AVeyp9sJmfD9
    Model: DMV-3016d
    Serial: AV4E0138
    Electric Drawing Number: AV5340A1A0
    PCM Prog No: AV53
    Edition No: E0
    Series: 4088 Edition: 02
    PMC Type Control: SA3
    Program: SA3
    Thanks!
    Feb 2013
    I am on vacation this week. I can help on Monday when I get back.
    Feb 2013
    see attached.
    Use your blue book for the keep relays that choose "how it functions"
    Attached Files Attached Files
