- Problem- Chamfer all the way around a hole on a bar
Hi I am trying to program a 2 mm chamfer around a 29mm hole on the outside diameter of 75mn bar with no success is there simple g code for this on a Dnm 400 machine Centre with fanuc control any feed back would be much appreciated thanks
- You may not post replies
- You may not edit your posts
Forum Rules
