- Need Help!- PUMA 8-HC troubleshooting flowchart
I'm working on a lathe which has suddenly decided to trip the main breaker instantly on startup when I press "MachineReady" button on panel. None of the internal circit breakers are tripped, however there is a smell in the control cabinet as well as a slight haze inside as well. I have been unsucessful in tracking down the source of the smoke and my documentation on the machine appears incomplete.
Obviously something very energetic is happening and I am wondering if there is a way to check the spindle motor amp without removing it and pulling it apart, It's my #1 suspect at this point.
The lathe was working fine on friday, this problem cropped up during startup this morning.
If anyone has a troubleshooting guide they could look at, maybe post a flowchart, I would be very grateful.
Serial # P8HC0173, has Fanuc 16-T control.
Re: PUMA 8-HC troubleshooting flowchart
Problem solved.
Input rectifier IGBT pair was toast (the 2 nearest the capacitors). Also a blown 5 amp glass fuse.
The output IGBT trio was fine.
The blown 5 amp fuse had me worried as that circuit goes up to the upper control board where all the logic resides so I tried looking for a replacement/rebuilt Amp unit without much luck.
All that was available was a used ebay unit for $3000 and it looked pretty dirty/ high hours.
2 IGBT modules and 2 capacitors came to $800 CAD so we decided to risk repairing it ourselves. Cleaned the board, sprayed the damage with conformal coating and replaced the caps and IGBTs.
On removing the old IGBTs I noticed that the screws that hold them to the heatsink (all 5 IGBTs) were barely finger tight and the heatsink compound was in terrible shape. I suspect these modules have been heat stressed for a long time due to poor mounting pressure which caused the startup failure.
I don't know if this is a common failure mode but would suggest that if someone has one of these Lathes still running with an original amplifier that it be taken apart and the IGBT's be reseated with good heatsink compound.
Lathe is back up and running.
- You may not post replies
- You may not edit your posts
Forum Rules
