- Need Help!- 31i spindle load programming
Hi just looking to see if someone could shed some light on how to go about using the m103/m104 spindle load command?
As the programming manual for the machine we have is missing before i started or it was never supplied with the machine (bought secondhand).
It could be the option is not turned on , on the machine however as i dont know how to go about calling it up it might be that.
ive used mori seki machines in the past with spindle load monitoring but that was g65 p9012 called or haas machines where by i set the load via the macro no. in the pgm.
bu this one seems to be a bit of a loss on me.
- You may not post replies
- You may not edit your posts
Forum Rules
