What is your serial number?
Gud day all, in urgent need of PUMA DAEWOO 6S FANUC OTC PARAMETERS
- I lost the original due to bad battery . Got a copy of some parameters but each with different problems
417 x axis dgtl parm
z axis dgtl parm
z axis over travel
even 409 serial error as spindle rotates at way too load speed and alarms out.
- Entering the pmc parameters or diagnostic parameters has not been possible. I have read all possible information and manuals i could get but can't still enter the pmc or diagnostic settings. I have however been able to get the CNC parameters via Rs232 and also how do i make a digital copy of these pmc parameters since they are appearing in this format X0000 000001011
I have the O-T parameters manual but i actually got lost in the tons of settings there.
Please any input will be greatly appreciated and sorry for my tons of questions , I am a complete newbie .
No longer with Doosan Machine Tools America
darrylhardt@gmail.com
Thank you for your prompt response
The machine is actually a Puma 8s machine but on the control I saw Puma 6s with Fanuc O-TC , I guess its an 8s w refurbished with Fanuc 6s control well i know little about that.
The serial number is: Puma 8S 0390 and
Puma 6s OT-C /F : 13686c at the control panel
Thank you so much. Please am at lost, how do i load diagnostic parameters, i have tried all possible ways to no avail
Maybe the Fanuc pdf can help.
Regards,
Heavy_metal.
Thank you so much but am unable to access it can you please mail it to mectrodream@gmail.com
Thank you in anticipation
Please the pmc parameters, are they same as diagnostic and can it actually affect the spindle speed and generate a 409 error with alarm 31
Here is what Doosan has on file. (generic Puma 6 with 0T control)
Originally Posted by RTS_Norway
Carried here from PM:
This is all the info I have in-house.
As the machine was never sold in the US, you would need to get a request for the actual machine parameters (if it exists) from your local support network.
Please give them the Serial number and request.
A search on Google shows the contact info for Norway to be:
P.A. BACHKE AS
Stanseveien 13 N-0975 Oslo
+47-21-061960
Hi and ty so much for your help so far. We have been in contact with them and the only answer was that they will send an email to the manufacturer and hope for the best, as this machine is discontinued the hope of getting any params was at best slim to none and it could take weeks for then to get an answer back. Our hunt continues...
Again ty for all help and assist
Regards RTS Norway
If they relay the information to Korea, which is the same thing that I would do for a USA machine, then they are looking for it, and should get a reply back as to availability,
Can you contact the company that you purchased it from to see if they kept a copy?
Here's a "shot in the dark"
Did you look in the back pocket, in the door of the electrical cabinet for the Original "Blue Book"
This 409 spindle error with alarm 31 is killing me Machine spindle rotates at very low speed and alarms out a 409 after some secs . Machine(Puma 8s with Fanuc O-TC Control) is lying almost completely useless now. I read about gapping the spindle magnetic pulse sensor. I have actually pulled out the spindle motor, opened it and did some test. Oscilloscope and multimeter reading show that only one phase is actually giving a waveform as the other phase remains at around 4.85 volt. Is this how it's supposed to behave, how do I know if the sensor is bad. Any help would be greatly appreciated as this machine is getting me really frustrated
I would say you are missing the spindle Paramaters to get it up and going at all
Looking for Parameters
Puma 6S Serial No. PM6S-223
Control FS OTC A02B-0098-B511
Master PCB A20B-2000-0170
Memory PCB A16B-2201-0101
I/O PCB A16B-1212-0220
Axis PCB A16B-2200-0391
Power Unit A16B-1211-0850
Spindle Drive A06B-6064-C312
Servo Amplifier A06B-6058-H223
Servo Motor X A06B-0314-B174R Model 5S
Servo Motor Z A06B-0314-B074 Model 5S
Spindle Motor A06b-0728-B202 Model 18P
Ladder 6SL-G
Servo Software 9040-H
Spindle Software 9A50-001K
When I saw this, last night, I requested a search for the parameter file or the Blue Book (The book that is in the pocket welded into the inside of the electrical door, that has the parameters) from Korea.
The machine is old, but they are looking for the file.
I received the file that you sent my email.
It is the generic file for any 2 axis lathe, with a 0TC control...Which is what you have.
The blank values are the "Machine Specific" ones. They need to be tuned to your specific machine.
If Korea finds your EXACT file copy, there might be a few less blank sections, but some that have numbers will still need to be "corrected" for any changes that happened over the years. (crashes, wear, disassembly/reassembly, time, fatigue, loads...)
The file that you sent me...might just end up being the best available. I will update you as Korea replies. (I should have an answer by tomorrow or at the latest Friday)
BTW: I'm not certain that your serial number is correct. I have a Puma 6G with that number, but not a 6S. Please check and verify the number (Send a picture of the placard to my email if needed)
