Just In Does anyone need service manuals for popular Doosan Machines? - Page 8
Page 8 of 9 FirstFirst ... 56789 LastLast
Results 141 to 160 of 179
Thread: Does anyone need service manuals for popular Doosan Machines?
  1. #141
    Oct 2006
    Chavornay
    Default Re: Does anyone need service manuals for popular Doosan Machines?
    I have to change the spindle's encoder belt on my Mynx 500.
    Is the 650 has similar spindle to 500?
    If you have something it would be great!
    Thank you!
  2. #142
    Jul 2010
    I need parts manuals for the following
    DMV 5025/50 SN AV630826
    DMV3016L SN MM4100395
  3. #143
    Member dhardt's Avatar
    Feb 2013
    Quote Originally Posted by dangilbert View Post
    Hello Darryl, I am wondering if you (or anyone on this list) has a manual for a Puma 8HC-3A ~1996 from DAEWOO, now Doosan. I have the operator's manual for the 16T FANUC control on the machine. I have run into a bunch of questions that are not answered in the FANUC manual, and am told that I need to ask the manufacturer. When I have questions about the FANUC controller, FANUC is awesome, but if it involves the operation of the spindle or tailstock I am told to contact the manufacturer of that part of the machine.
    The machine predates the time that Doosan started creating MTE manuals, (Maintenance Technical English) and ISE manuals (Install Service English) so the only manuals available are the ones that originally were sent with the machine. These have actual part numbers to there editions that are sorted by Machine Serial Number.
    Please contact you local dealer to purchase replacement manuals of PLE (Parts List English) OPE (Operation Programming English) INE (INstruction English) or the Electrical Diagram (which has its own code format to its version.
    No longer with Doosan Machine Tools America
    darrylhardt@gmail.com
  4. #144
    Feb 2013
    Quote Originally Posted by lstoeckl View Post
    thank you for providing the maintenance manual for the Puma 240M - it was of great help.
    Do you also have a maintenance manual for Puma 2600LM and Puma 3100Y, year of manufacture 2012?
    Thanks in advance!
    I have an MTE manual for the smaller version of both of those machines. The Puma 2100. The procedures are very similar, but any parts referenced would need verification from the correct parts manual.
    The file is too large to attach here. If still needed, please email me a request at the email address in the footer of any one of my posts.
  5. #145
    Feb 2013
    Quote Originally Posted by atrus9999 View Post
    The parts manuals are one of the ones that originally were sent with the machine. These manuals have actual part numbers to there editions that are sorted by Machine Serial Number.
    Please contact you local dealer to purchase any replacement manuals of PLE (Parts List English) OPE (Operation Programming English) INE (INstruction English) or the Electrical Diagram (which has its own code format to its version.
  6. #146
    Feb 2013
    Added note: I can post or email small sections of the parts manuals to assist with an immediate repair, but entire manuals need to be ordered from your local dealer, please.
  7. #147
    Feb 2013
    Quote Originally Posted by mcbress View Post
    Thank you!
    That Mynx 500, does its serial number begin with AV5E?
    It comes in a #40 taper, a #50 taper, and each version had either with or without through spindle coolant...Which is yours?
    Attached is a visual comparison of the Mynx 650 structure to the AV5E 40 taper with TSC
    Attached Thumbnails Attached Thumbnails Does anyone need service manuals for popular Doosan Machines?-actuator-compare-mynx650-av5e-jpg
  8. #148
    Member juanjome's Avatar
    Mar 2020
    I am looking for service literature for a Daewoo Mynx 500 with -Fanuc 21-M Series CNC Control, with parameters
  9. #149
    JanRysselPaulsen's Avatar
    Jul 2019
    Kolind
    Hi dhardt
    any chance you got the komplete keep relay descriptions list for doosan ST20G swissturn year 2012/2013
    the manual delivered with the machine stops at K13.0
    bedst regards Jan
  10. #150
    Aug 2007
    Hello Daryll, Is there a maintenance manual available for the Lynx 220 LM C axis lathe?
    Cheers
    Dean Davidson
  11. #151
    desertratt's Avatar
    Aug 2020
    Hi, were you able to find this information? I am facing a similar situation.
  12. #152
    Member MrBates's Avatar
    Sep 2020
    Evening.
    I have an issue with Doosan HM 1250 ATC. For some reason it has lost few of it's home positions, waiting pot and 180 turning arm.(also there's an issue with the arm rotating on it's own when hydraulics are on)
    Looking for maintenance manual for the ATC.
    Thanks for the help in advance!
  13. #153
    Member Basham's Avatar
    Jan 2020
    Hi
    I need maintenance manual cnc lathe
    Doosan turn4 please help me
  14. #154
    Feb 2013
    Quote Originally Posted by JanRysselPaulsen View Post
    Hi dhardt
    bedst regards Jan
    As the swiss turns are not sold in the Americas, I do not have access to anything Swissturn
    Except this:
    https://drive.google.com/file/d/1F66...ew?usp=sharing
  15. #155
    Feb 2013
    Quote Originally Posted by MrBates View Post
    Evening.
    All things HMC1250 (machine and ATC)
    https://drive.google.com/file/d/11Z8...sp=sharing,%20
    https://drive.google.com/file/d/124b...sp=sharing,%20
    https://drive.google.com/file/d/17Mr...ew?usp=sharing
  16. #156
    Feb 2013
    Quote Originally Posted by Basham View Post
    Hi
    Unfortunately, that machine precedes the time that we have created Service Manuals, so I have nothing on it.
  17. #157
    Feb 2013
    Quote Originally Posted by desertratt View Post
    Without a text quoted in your request I have no reference as to what your "similar situation" is...
    What is the issue you are having?
  18. #158
    Member tecram's Avatar
    Mar 2021
    Hi i need maintenance manual for Puma MX2500LST
  19. #159
    Member Reynabmg's Avatar
    Sep 2020
    Hello friend, Doy ou have the DMN5700 Installation and Operational manual available?. Thanks and best regards.
  20. #160
    Jsb67's Avatar
    May 2021
    Do you have manuals for daewoo solar 220 LC-V excavator? Operators manual and shop/service manual
