How do you mill a hexagon on lynx220lm lathe using live tooling ? Please help me
Results 1 to 20 of 20
Thread: How do you mill a hexagon on lynx220lm lathe using live tooling ? Please help me
    Default How do you mill a hexagon on lynx220lm lathe using live tooling ? Please help me
    Using Tapatalk
    Oct 2012
    Netherlands
    This is possible,
    How are you planning to program?
    ez-guide? or g-code? CAM?
    G code or I've got mastercam 9
    Using Tapatalk
    Dec 2012
    The Netherlands
    Default C-axis
    This is a G-code for a 50mm Hexagon with an axial-live tool, Fanuc 18T.
    Maybe you need other M- or G-codes.
    Look also at the Doosan attachment for c-axis milling and side drilling/tapping.
    When you use Mastercam 9 you need a proper post-processor.
    O1111 ( HEXAGON - 50MM )
    ( AXIAL LIVE_TOOL )
    T0101 G98
    M86 ( C-AXIS CONTROL ON )
    G97 S3500 M3
    /M8
    G0 X90. Z10. C0
    G1 Z-5. F2000
    N1 G112 ( OR G12.1 )
    G1 G41 X50. C14.43 F500
    X50. C-14.43
    X0 C-28.86
    X-50. C-14.43
    X-50. C14.43
    X0 C28.86
    X50. C14.43
    G40 X90. F2500
    N2 G113 ( OR G13.1 )
    G1 Z2.
    G0 Z50. M5
    X250. Z200. M9
    M85 (C-AXIS CONTROL OFF )
    M30
    Regards,
    Heavy_Metal.
    Attached Thumbnails Attached Thumbnails How do you mill a hexagon on lynx220lm lathe using live tooling ? Please help me-c-axis-jpg   How do you mill a hexagon on lynx220lm lathe using live tooling ? Please help me-doosan-30-series-rotary-axis-functions-pdf
    Thanks ill give it a go my control is fanuc oi- tc so might have to change some codes much appreciated
    Using Tapatalk
    Does that program do it in 1 cut what about a really heavy hex, can you rough it in a canned cycle ? Regards Matt
    Using Tapatalk
  7. #7
    Dec 2012
    The Netherlands
    Hi Matt,
    This was a try-out on a Delrin (PCV/Plastic) round bar with a 10mm mill, one cut.
    You can program multiple passes or start with a large offset, maybe Mastercam can help with the g-code.
    Regards,
    Heavy_Metal.
    Attached Thumbnails Attached Thumbnails How do you mill a hexagon on lynx220lm lathe using live tooling ? Please help me-c-axis-2-jpg
  8. #8
    Than you
    Using Tapatalk
  9. #9
    What number do to put in the T column in geometry page please and r for milling a hex
    Using Tapatalk
  10. #10
    Dec 2012
    The Netherlands
    Default Geometry for C-axis
    Hi Matt,
    How do you mill a hexagon on lynx220lm lathe using live tooling ? Please help me-geom-jpg
    Regards,
    Heavy_Metal.
  11. #11
    Thank you the 50 mm hex program worked a treet but I've just done a 35mm a/f and the flats look slanted could you show me a program to see what I'm doing wrong sorry to be a pain thanks matt
    Using Tapatalk
  12. #12
    Dec 2012
    The Netherlands
    Hi Matt,
    The next code should work.
    When you stop between line N1 and N2 you have to execute, in MDI-mode, the code G40 G113 (G13.1).
    It is not possible to make the sides 100% flat, than you have to mill with an Y-axis or a VMC-centre.
    Maybe you have to reduce the Feed-rate for a better result.
    O1111 ( HEXAGON - 35MM )
    ( AXIAL LIVE_TOOL )
    T0101 G98
    M86 ( C-AXIS CONTROL ON -FANUC-18T )
    G97 S3500 M3
    /M8
    G0 G40 X75. Z10. C0
    G1 Z-5. F2000
    G1 G41 X35. C10.105 F500
    X35. C-10.105
    X0 C-20.21
    X-35. C-10.105
    X-35. C10.105
    X0 C20.21
    X35. C10.105
    G40 X75. F2500
    G1 Z2.
    G0 Z50. M5
    X250. Z200. M9
    M30
    How do you mill a hexagon on lynx220lm lathe using live tooling ? Please help me-hex-35mm-jpg
  13. #13
    I will try this tommorow , really appreciate your time thanks
    Using Tapatalk
  14. #14
    I wonder if a 1/2 solid carbide end mill will be better as I'm only using a standard and sticking out 41mm what's the best cutter for this type of machining is it a ripper?
    Using Tapatalk
  15. #15
    Dec 2012
    The Netherlands
    Hi Matt,
    Solid carbide is always better (for steel) than HSS/Co but needs stability and no vibrations.
    You can use a rough/ripper mill when the smoothness of the surface is not so important.
    I don't know what the material is for your job.
    There are a few things that matters:
    * cutting depth (radial)
    * Z-depht (axial)
    * lenght of the tool
    * Feed and Speed
    * stability toolholder and tool
    * power live-tools
    Regards,
    Heavy_Metal.
  16. #16
    Thanks I think I'll go with the solid carbide but the maximum cutter I can use is 1/2 inch as that's the biggest collet I have regards matt
    Using Tapatalk
  17. #17
    Default Re: How do you mill a hexagon on lynx220lm lathe using live tooling ? Please help me
    Quote Originally Posted by Heavy_Metal View Post
    Hi Matt,
    * Z-depht (axial)
    * Feed and Speed
    * power live-tools
    Regards,
    Heavy_Metal.
    Hi mate is there a simple way to program a 2mm chamfer on a 29mm hole on a 75mm diameter bar on a doosan Dnm mcenter with fanuc control thanks matt
    Using Tapatalk
  18. #18
    Aug 2015
    I'm currently not seeing the results I'd like with the G12.1. Attached is the current code (Citizen L20-Mitsubishi control) and the blueprint. The print is in inches but the program is in metric. I programmed the final part dimension + the radius of the tool (.125"), this way the R value on the offset screen is 0.
    The issues are as follows, the final dimension is approximately .032" to big on the .072" +0./-.004" dimension(width across flats). I've programmed the X and C axis radially. I verified that the tool is centered (X0./Y0.) to the sub-spindle.
    Also, there's no .127mm(.005") radius on the corners of the square.
    As the program reflects I'm using G41 and G2's. Per the attached picture captured from the Instruction Manual for the Citizen L20, I should be using G42 and G3's, which is correct? I'm wondering if this is why my part has no .127mm(.005") radius on the corners of the square?
    Thanks in advance for the support.
    Attached Thumbnails Attached Thumbnails How do you mill a hexagon on lynx220lm lathe using live tooling ? Please help me-fsp-jpg   How do you mill a hexagon on lynx220lm lathe using live tooling ? Please help me-g41-g42-jpg
    Attached Files Attached Files
  19. #19
    May 2016
    United Kingdom
    I know this is probably a late answer but I am sure you will find this of use, very basic but I use it on my Lynx 220 and it works fine. you might have to play around with the speed/feeds for your material but hey ho
    O4483(SUPER MILL HEX EXT)
    (TURNING DIA = ACROSS FLATS *1.154)
    #1=50(ACCROS FLATS)
    #3=1(DEPTH OF CUT IN Z)
    #4=15(LENGTH OF FLAT Z)
    #5=0.(NULL VALUE)
    #6=8(DIAMETER OF CUTTER)
    #7=.57735(MAGIC TAN 30 DEGREES)
    #10=#1+#6(MAGIC X)
    #11=[#10*#7]/2(MAGIC C)
    #12=#10*#7(MAGIC CX)
    N1(8MM CUTTER)
    T0707M05
    M28 (C AIS ON)
    G28H0
    G0C0
    M3G97S3000
    G98
    G00X0.Z20.M8
    Z1.
    G12.1 (POLAR ON)
    G01X-#10C#11F2000 (MOVE TO START)
    N4(HERE WE GO)
    #5=#5+#3
    IF[#5GT#4]GOTO5
    Z-#5F200
    C-#11
    X0.C-#12
    C-#11X#10
    C#11
    X0C#12
    G01X-#10C#11
    GOTO4(DO IT AGAIN)
    N5(ALL DONE)
    G1Z1.F2000
    G13.1 (POLAR OFF)
    G99
    M5
    G0Z20.
    M9
    M29 (C OFF)
    G28U0.W0.
    N30M30
  20. #20
    Member DouglasR's Avatar
    Jul 2005
    Correct. G12.1 is used with G13.1 to cancel. If you'd like the classroom manual on this, please email me.
