Need Help! Doosan tt1800sy
Results 1 to 11 of 11
Thread: Doosan tt1800sy
    Apr 2008
    Default Doosan tt1800sy
    I wondering if there is a parameter that can make
    The machine ignore wait codes when you are running only one side
    Member chucker's Avatar
    Nov 2007
    Can you put a \ in front of your wait code then turn on block skip?
    Apr 2008
    yes that works but I am afraid that someone will forget to turn it off
    when they go back to multi
    we have a nakamura wt100 and it just skips over wait code when running one
    side
    Member dcoupar's Avatar
    Mar 2003
    Yes. I believe it's keep relay 0 bit 7 (not parameter), but don't quote me. Look in the blue binder in the electrical cabinet. There's a section in the back half that details the keep relays.
    Apr 2008
    thanks I will check next week when I go back to work.
    I will post how I make out
    Jun 2007
    In my book it is listed as K0.0
  7. #7
    Apr 2008
    Thanks that works
    Keep relay k0.0 change from 0 to 1
    TT 1800 SY
    Fanuc 18i -tb
  8. #8
    Mar 2003
    Quote Originally Posted by Don18P View Post
    I knew it was one end of K0 or the other. I don't have a book, and my memory isn't what it once was.
  9. #9
    Apr 2008
    I couldn't find in the book but tried it and it worked thanks all
  10. #10
    Jun 2006
    Default Re: Doosan tt1800sy
    Technically that's pretty dangerous if your program has crossovers, you could send a tool into a hole the lower was supposed to drill if it ignored wait codes.
  11. #11
    Jun 2006
    I was wrong. I guess the machines typically ignore wait codes running only one side. I hope you found the answer to your question.
Doosan tt1800sy
Doosan tt1800sy
