Need Help! Daewoo PUMA 8HC Parameter required
Results 1 to 2 of 2
Thread: Daewoo PUMA 8HC Parameter required
    Jul 2012
    Pakistan
    Question Daewoo PUMA 8HC Parameter required
    Hi!
    We buy a used Daewoo Puma 8HC with Fanuc OT B control,year 1989. But unfortunately battery during transportation, Now we need its parameter and diagnostic parameters.
    Kindly help me,
    Member EtienneC's Avatar
    May 2022
    Default Re: Daewoo PUMA 8HC Parameter required
    Hi did you manage to get the parameters ? Here is the files if still needed
    Cheers !
    Attached Files Attached Files
    Kasha's Avatar
    Mar 2023
    We also have a Daewoo PUMA but differs in that it's a 10-HC, Serial Number PH100Z08 and due to a dead battery, we've also lost the parameters. Will these parameters work with it? If not, do you have the parameters for our machine?
