You should check parameters to see if those program number are being called by M-codes (6071-6079, 6080-6089) or G-codes (6050-6059). If these parameters have values in them, then that program may need to remain unchanged.
6071 M code that calls the subprogram of program number 9001
6072 M code that calls the subprogram of program number 9002
6073 M code that calls the subprogram of program number 9003
6074 M code that calls the subprogram of program number 9004
6075 M code that calls the subprogram of program number 9005
6076 M code that calls the subprogram of program number 9006
6077 M code that calls the subprogram of program number 9007
6078 M code that calls the subprogram of program number 9008
6079 M code that calls the subprogram of program number 9009
6080 M code that calls the custom macro of program number 9020
6081 M code that calls the custom macro of program number 9021
6082 M code that calls the custom macro of program number 9022
6083 M code that calls the custom macro of program number 9023
6084 M code that calls the custom macro of program number 9024
6085 M code that calls the custom macro of program number 9025
6086 M code that calls the custom macro of program number 9026
6087 M code that calls the custom macro of program number 9027
6088 M code that calls the custom macro of program number 9028
6089 M code that calls the custom macro of program number 9029
6050 G code that calls the custom macro of program number 9010
6051 G code that calls the custom macro of program number 9011
6052 G code that calls the custom macro of program number 9012
6053 G code that calls the custom macro of program number 9013
6054 G code that calls the custom macro of program number 9014
6055 G code that calls the custom macro of program number 9015
6056 G code that calls the custom macro of program number 9016
6057 G code that calls the custom macro of program number 9017
6058 G code that calls the custom macro of program number 9018
6059 G code that calls the custom macro of program number 9019
