- Pocket around a profile
Hi.
I'm new to Cut2D and just learning.
My test is a .5" thick workpiece. I'd like to cut (profile) a hole all the way through, and pocket (to .125" depth) a recess around the hole.
When I do this, it appears the pocket doesn't take into account the hole, so there is a whole lotta extra cutting of air.
Think of this example as recessing a speaker driver in a baffle, so the hole is cut, and a recess added for the flange of the driver.
I'm including two pics of what I'm see, I would have through the software would have "noticed" the through-hole and stopped pocketing.
What am I doing wrong?
BTW, it doesn't matter which order I perform the operations, pocket first profile 2nd or vice versa, I get the same result.
Re: Pocket around a profile
I figured it out. I had to ad another circle inside and allow for at least enough room for the bit, select both shapes and then do the pocket.
Pretty neat software for a guy coming from LazyCam.
- You may not post replies
- You may not edit your posts
Forum Rules
