- CSMIO/IP-M Output/Enable issues
I'm trying to connect a Clearpath SDSK servo which requires a enable signal from Mach3 to energize it.
I have hooked up +24V to Pin9 and 0V to Pin22 (power for the outputs).
I'm using Output0 (Pin10) on the CSMIO and Port10 as the port.
The Enable output in Mach3 lights up.
I don't get any output signal. What am I missing?
- You may not post replies
- You may not edit your posts
Forum Rules
