I trashed these boards ( had two of them ) , purchased UCCNC AXBB-E for my 4 axis and RosettaCNC for my 5 axes...
I have the NVCM6V2.1 board and I'm using Mach3.
I'm trying to set an output and control it using M11/M10 but for some reason it does not succeed.
What I've done so far: I have connected output TX16 to my laser module and defined it as output6 in Mach.
For the test - If I'm setting the coolant to out 6 it can start and stop the laser, SO I know all electronics is connected fine. the pin is correct and output 6 is set properly.
BUT...
When I'm trying to use m11 command it does nothing. (tried all kind of syntaxes including the ones that includes movement like M11P6 G0 X100)
How do I trigger outputs on the NVCM via Gcode?
BTW,
Just for the test, I created a new profile in Mach based on my current one and replaced the breakout board with an old LPT one that I have and there M11 does work so I assume mach's macros are ok (cannot use that board because it is short on ports)
Gil
- Need Help!- Novusun NVCM Motion Controller Enable PWM
- Need More Outputs
- Need Help!- G32 outputs E instead of F
http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
http://my-diysolarwind.blogspot.com/
