Hi I have just built a cnc controller using Nvem ver 2 with TB6600 motor controllers.with Mach3
1: wired correctly but in the jog pannel Y moves the Z axis, Z moves the X axis and X moves the Y axis.. How can I change this.
2:in Mach3 port and pins what is the setup so I can check mine are correct
managed to get the controller to connect to pc
just all the other settings
Thank you for your time
