Newbie UCCNC400ETH & Mach3?
Results 1 to 4 of 4
Thread: UCCNC400ETH & Mach3?
    Jan 2018
    United Kingdom
    Default UCCNC400ETH & Mach3?
    Noob question.
    Anyone using this combination of UCCNC400 & Mach3?
    I've seen a plugin for it but is the setup stable?
    Should I just go with the ESS Smoothstepper and not look at anything else when the time comes?
    Mar 2003
    Shelby Township
    Default Re: UCCNC400ETH & Mach3?
    It should be just as stable as the ESS.
    I'd recommend the AXBB-E. It has more features, and you don't need a breakout board.
    I'd also pay the $60 and switch to UCCNC, which is far superior to Mach3.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
    Jun 2015
    Sweden
    Quote Originally Posted by dazp1976 View Post
    Noob question.
    I used that combination for some time and it worked fine, but then moved to UCCNC.
    Aug 2015
    Uccnc is better than mach 3 .
    I wolud not use mach 3 after i use uccnc .
