Need Help! WIXHC MK6-V Motion card on Mach3 Enable output
Results 1 to 4 of 4
Thread: WIXHC MK6-V Motion card on Mach3 Enable output
    Feb 2016
    Default WIXHC MK6-V Motion card on Mach3 Enable output
    I have upgraded my breakout board with a USB MK6-V motion card. I'm having an issue with the enables outputs from Mach3. My gantry mill servo drives are staying enabled. I'm using outputs 3 and 4 for enables pin set. Mach 3 has them showing they are off when estopped. But the terminals stay on. I have checked the pinout 2 and 3 for the outputs on the card. When I hit my estop or click the reset"estop" on Mach3 screen they are staying on. Before the sway they would turn off. Then when cleared from Mach3 screen would enable. I tested the pinout as an output conf. and can turn the terminals on and off just fine. But set as an enable in output setting with the pinout 2 and 3 they just stay on? I would like the drives to be disabled when I hit the estop or as usually click the on screen reset "estop". Maybe the motion card doesn't work with MACH3 enable conf.? Can I set something to use a normal output setting to use as an enable when estopped?
    ThX
    Feb 2016
    Default Re: WIXHC MK6-V Motion card on Mach3 Enable output
    The enable settings in Mach3 output conf. does not turn off the card output when the estop is pushed. Can a macro or brain be writen to make a mach3 "output" come on/off with the estop or mach3 screen estop?
    So the Mach3 screen would be turning on/off output #3 with estop. Rather than the enable #1. I have the pinout # set right I can manually turn them on/off when set as output #x.
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Most likely an issue with the plugin. Most if not all Chinese Mach3 controllers have some features that don't work properly.
    UCCNC 2017 Screenset
    Feb 2016
    OK. I figured how to fix my issue. I made a macro. M202 Activatesignal(OUTPUT3). Then went to General Config. to initialzation string added m202 and clicked ALL RESETS. Now Output #3 comes on/off on Mach3 and terminal. I tried all the same for ENABLE but didn't work. But that is fine I can use the labeled Outputs for each of my enables needed. Anyone could probably do this for anything on a output they would want to come on for when an estop isn't set. Enable just doesn't work for me with this card.
