Does anyone have any experience with this Amazon CNC Controller
Results 1 to 4 of 4
Thread: Does anyone have any experience with this Amazon CNC Controller
    Gold Member Mr.Chips's Avatar
    Sep 2003
    Gilbert Az
    Default Does anyone have any experience with this Amazon CNC Controller
    I have a 3x4' homemade CNC, using two ball screws on the Y axis, acme threaded X and Z axis, and linear rails and trucks on all axis.
    Using Gecko 251X drivers, Mach3 and Vectric VcarvePro 8.5.
    Has anyone used the below Controller cards sold by L-STAR MOTOR from Amazon. I'm considering clanging my Controller boards to a more modern board at an attrive price.
    It is a 5 Axix Mach3 Stepper motor comtroller board, breakout board interface fot CNC
    Router, engraving, milling machine.
    Mr Chips
    Attached Thumbnails Attached Thumbnails Does anyone have any experience with this Amazon CNC Controller-controller-jpg
    Member mactec54's Avatar
    Jan 2005
    Default Re: Does anyone have any experience with this Amazon CNC Controller
    Quote Originally Posted by Mr.Chips View Post
    Mr Chips
    Many have used similar Breakout Boards to this I not sure you need one with ( 3 ) relays on it you only need ( 1 ) for your spindle
    Mactec54
    Sep 2003
    Gilbert Az
    Thanks,
    That’s correct, one is enough.
    I was hoping to find someone that has used this board, they have good reviews on Amazon.
    But at $25 it’s nit a bank buster. I’ll give it a couple of days before I order one.
    Dec 2005
    Thanks,
    Did you have any luck out of yours?
    I got this several weeks back and finished up my electronics this week. This damn board has ran me wild. 3 computers later Win7 32bit and XP 32bit. All pc's output correct voltage at port and cable end but once plugged into this BOB I just get 4.10v no matter the step direction (hi/low) so the prob is with this board.
    I order another with the same features but totally different brand etc on Amazon.
    https://www.amazon.com/Keenso-Controller-Interface-Engraving-Breakout/dp/B07PSJF5HN/ref=mp_s_a_1_1?keywords=keenso+breakout+board&qid= 1565222869&s=gateway&sr=8-1
