Mesa Card Help
Results 1 to 8 of 8
Thread: Mesa Card Help
    Dec 2006
    Default Mesa Card Help
    Hi guys,
    Need a lil help understanding the mesa card.. specifically the "D" card my confusion is in the 24 volt portion ... one provides 24 volts for all the ancillary options and one provides the ground ?
    maybe it was just the way it was explained to me
    thanks in advance
    Joe
    Feb 2008
    Default Re: Mesa Card Help
    Which mesa card do you have?
    Dec 2006
    i have not purchased it yet but im looking at one of the plug and go kits possibly the 7I76-5I25 PLUG-N-GO KIT
    Dec 2006
    im looking to outfit 2 bridgeport machines 4 axis maybe 5 with auto oiler fog buster coolant maybe spindle speed control via vfd
    and a lathe 2 axis with vfd spindle speed control and fog buster coolant control
    Feb 2008
    If you are asking about the 7I76/7I76 D difference, the only difference is that the 7I76 has sourcing field I/O outputs and the 7I76D has sinking outputs
    That is the 16 7I76 field outputs source +12 or +24V to the load (so the load common is power supply common):
    7I76 output --> relay coil --> common (or ground)
    The 16 7I76D field outputs are sinking so load common is +12 or +24V:
    +24V --> relay coil --> 7I76D output
    Dec 2006
    thanks, yes that is what im confused about.. so the 7i76 outputs 12 or 24 volts to the relay and thats what triggers the relay to make the connection from the 12 or 24 volt main powersupply to the peripheral ?
  7. #7
    Feb 2008
    Yes, if you think of the 7I76/7I76D outputs as switches, the 7I76 has a common +12/+24V for all 16 "switches" and the 7I76D has a common negative (ground) for all switches
  8. #8
    Dec 2006
    thank you for that information !
Mesa Card Help
Mesa Card Help
