CNC USB MACH3 100Khz Breakout Board problem
Results 1 to 6 of 6
Thread: CNC USB MACH3 100Khz Breakout Board problem
    Aug 2017
    Bosnia And Herzegovina
    Default CNC USB MACH3 100Khz Breakout Board problem
    CNC USB MACH3 100Khz Breakout Board problem with auto tool probe .not work with the plugin( RnR MOTION plugin).I would ask for instructions on this board??thanks
    Attached Thumbnails Attached Thumbnails CNC USB MACH3 100Khz Breakout Board problem-plocicca-jpg
    Mar 2003
    Shelby Township
    Default Re: CNC USB MACH3 100Khz Breakout Board problem
    Probing does not work properly with most of the chinese Mach3 controller boards.
    Make sure the probing macro you are using does not use the GetVAR() command, as that's often where they fail.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
    Aug 2017
    in the Diagnostic window in mach 3 digitize bright continuously picture scheme of connection...CNC USB MACH3 100Khz Breakout Board problem-untitled12-jpgCNC USB MACH3 100Khz Breakout Board problem-untitled1-jpgCNC USB MACH3 100Khz Breakout Board problem-untitled-jpg
    Attached Thumbnails Attached Thumbnails CNC USB MACH3 100Khz Breakout Board problem-untitled12-jpg   CNC USB MACH3 100Khz Breakout Board problem-untitled1-jpg   CNC USB MACH3 100Khz Breakout Board problem-untitled-jpg
    Member ZASto's Avatar
    Apr 2005
    Vanuatu
    Try to invert active state of probe signal in settings.
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
    Aug 2017
    Quote Originally Posted by ZASto View Post
    this board definitely has a problem
    Jun 2010
    What Jerry wrote.
    Cheers
    Roger
