Question. The enable pin for the motor connections on the Pokeys57cnc, are labeled "Enable Inverted". What does that mean ?? Is it grounding or powering the enable pin ?? So does this go to Enable + or Enable -Similar Threads:Need Help!- Pokeys57cnc board questions Mach 4 and Pokeys57cncNewbie- Using Pokeys57cnc and UCCNC softwareNewbie- NEED HELP with connecting my VFD/Spindle to Pokeys57CNC board.Need Help!- uccnc with pokeys57cnc
Originally Posted by Miamijerry Question. The enable pin for the motor connections on the Pokeys57cnc, are labeled "Enable Inverted". What does that mean ?? Is it grounding or powering the enable pin ?? So does this go to Enable + or Enable - It means it's enabled when it's off (deactivated)
Originally Posted by Miamijerry Question. The enable pin for the motor connections on the Pokeys57cnc, are labeled "Enable Inverted". What does that mean ?? Is it grounding or powering the enable pin ?? So does this go to Enable + or Enable - Having read the manual it goes to the enable +, and you wire the enable - to gnd
Originally Posted by robertspark Having read the manual it goes to the enable +, and you wire the enable - to gnd Thank you
View Tag Cloud
Forum Rules
