Need Help! Help with Novusun NVUM V2 USB control card - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
Thread: Help with Novusun NVUM V2 USB control card
  1. #21
    Sep 2005
    Default Re: Help with Novusun NVUM V2 USB control card
    Quote Originally Posted by ZASto View Post
    HI,
    what kind of support you have from linked seller? The board at China costs less than $20 (approx 13€ with shipping).
    Just take a look at the Mach forum. It's up to you that live in belief that paying $90 for a $20 product will provide you a quality support.
    Guy, ah it sells as above on the link I posted for $89 in the USA, so what the hell are you talking about!! The NVMU or whatever I did not buy! The one below that is what I have ordered.
    Help with Novusun NVUM V2 USB control card-cncboard-jpg
    Help with Novusun NVUM V2 USB control card-pmdx-jpg
    1000x750 Workbee CNC - Mach4 - PMDX USB - Windows 10 Pro
  2. #22
    Nov 2013
    That means you are being ripped, they are available for $20 elsewhere. To be honest I think $20 is a rip too.
    Craig
  3. #23
    Sep 2005
    Ok Craig the floor is all yours... have at it. Thanks for your help.
  4. #24
    Member mactec54's Avatar
    Jan 2005
    Craig
    They may not be the same boards the cheap one's may be copies of the original manufactured board this happens a lot $89 sounds about right for a 100Khz board if you compare it with the 100Khz UC100 it is a little cheaper than the UC100 at $89 so may not be a rip off at all get the facts correct, what you are saying is not credible as you don't have hands on experience with this board
    Remember electronically challenged installer's will have trouble with any system no matter how fool proof they are made what you see on the forums is typical of people in need of help and 99% are electronically challenged
    I have no use for one of these boards but will buy one just to see if they are bad or not
    Mactec54
  5. #25
    Member pociu's Avatar
    Feb 2021
    Quote Originally Posted by Galoptic View Post
    I have had the same problem after six months use started getting load BIN file message. Anyway after much searching found BIN file and loaded it all good again. the BIN file can be downloaded from following link on the Novusun web page. https://www.nvcnc.net/nvum.html Button bottom middle of screen. Or direct link https://www.nvcnc.net/pdf/nvum.bin.rar
    John
    Hello Galoptic
    I would like to ask you where you finded bin.file for novusun. I am looking for the bin file for NVEM V2. I suspect that after the connection analog output of spindle to the analog input of inverter the firmware was cleared. Something goes wrong. NVEM worked ok ealier after this situation NVEM not respodnds.
    Thank you in advance for your responce
  6. #26
    avtostv's Avatar
    Mar 2021
  7. #27
    Dec 2017
    Belgium
    Quote Originally Posted by pociu View Post
    Hello Galoptic
    Files for NVEM here https://www.nvcnc.net/nvem.html
  8. #28
    Member aligaman's Avatar
    May 2021
    Hi Streumer,
    the NVUM-bin file link above has been broken for a while (404 Not Found). it would be a great help if you have the bin file on google drive or a sure download link! I can't find it anywhere online.
    thank you
  9. #29
    Jan 2018
    United Kingdom
    I can sum this up in 2 mins.
    The website likely hasn't been updated in last 10 years.
    They never patented the controller.
    The ones you buy now are copies of the original.
    Support does not exist.
  10. #30
    Dec 2017
    Belgium
    Quote Originally Posted by aligaman View Post
    Hi Streumer,
    thank you
    pm ME
  11. #31
    amin485's Avatar
    May 2021
    This link to nvum firmware bin file does not work. COuld you please send the file or a valid link?
    I am very in need to fix my novusun cnc controller.
    thanks,
  12. #32
    Jul 2013
