Newbie RichAuto A11 - DSP fails to initiate / Should I go Mach3??? -NEED HELP-
Results 1 to 10 of 10
Thread: RichAuto A11 - DSP fails to initiate / Should I go Mach3??? -NEED HELP-
    Apr 2018
    United Kingdom
    Default RichAuto A11 - DSP fails to initiate / Should I go Mach3??? -NEED HELP-
    RichAuto A11(S) - DSP fails to initiate
    Hi. This is my first post on this site, so please excuse me if I'm not posting in the right place.
    I have a Chinese machine (OMNI-CNC Jinan 1325) with RichAuto A11 DSP controller and a MACH3 controller (I've never run it from the Mach3 controller... wonder if that is part of the problem?!)
    Everything has been running fine... until I switched off the power (mains) for about 3 weeks and when I came back, the machine powered up ok and the DSP lights up, but no menus... nothing.
    I've tried unplugging DSP from controller, holding down the OK button for extended time (as suggested in another post on here). I can't seem to get it going ~at a loss for what to do.
    Can anyone help out??
    Thanks in advance!
    25 April. 2018
    I've contacted the Chinese manufacturer and they say the only solution is to return the DSP & board for repair (to China... 4-6 weeks)
    Also, there is a Mach3 board on the machine but I've not run it. Is it a better solution to be running Mach3??? I'll need to get a dedicated computer.
    PLEASE HELP ---- MACHINE IS DEAD IN THE WATER UNTIL THIS IS RESOLVED ----
    Attached Thumbnails Attached Thumbnails RichAuto A11 - DSP fails to initiate / Should I go Mach3??? -NEED HELP--img_9417-jpg   RichAuto A11 - DSP fails to initiate / Should I go Mach3??? -NEED HELP--img_9418-jpg   RichAuto A11 - DSP fails to initiate / Should I go Mach3??? -NEED HELP--img_9421-jpg   RichAuto A11 - DSP fails to initiate / Should I go Mach3??? -NEED HELP--img_9420-jpg
    Apr 2018
    Default Re: RichAuto A11 - DSP fails to initiate / Should I go Mach3??? -NEED HELP-
    wow the planets must be in a bad place.
    I have a RZNC DSP handheld controller.
    Last night went out to start up the cnc and same thing..lit up..no response.
    I connected it to laptop nearby. I could see the filenames in it had odd characters - gibberish actually, not chinese.
    Contacted mfr they sent me the manual...lol...then told me to watch a video on youtube..lol
    Now they have me in the queue for tech support.
    Machine is a month and a half old.
    Apr 2018
    update.
    Got up at 3am to go live with the tech in China.
    emailed me the file to reinitialize the dsp, and it works now.
    Apr 2018
    United Kingdom
    Quote Originally Posted by CaistorAl View Post
    update.
    Did you connect direct to laptop via USB?... did the DSP boot that way?
    I have a parameter backup file, but can't get dsp to boot up.
    Would you mind sharing the initialization file? Was it for an A11 DSP?
    The china tech for my machine wants me to send it back to them with the board. (machine will be down 4-6 weeks)
    It's partly why I'm thinking to switch over to Mach3.
    Apr 2018
    yes it was for an A11 dsp
    the tech emailed me the initialization file.
    worked like a charm.
    then I had to get the submenus out of chinese into english.
    pm me your email, and I'll send you what I have, along with instructions.
    Bear in mind, it takes patience, I had to figure some of this out, but in all it took me 15mins and it worked.
    Al
    shhadamousa's Avatar
    Sep 2018
    Hello
    I have the same problem that happened with CBurr
    I hope you send anything that can help me solve that problem
    Thank
  7. #7
    *Registered User* kam50's Avatar
    Oct 2018
    Dear all
    Can body send me *.PKG file to make my richauto A11 DSP reborn
  8. #8
    *Registered User* Tycruz's Avatar
    Oct 2018
    Hello
    Can you also send the files and instructions to me please Thank you.
  9. #9
    *Registered User* RafaSP88's Avatar
    Oct 2018
    Ordering a 1325 with Omni, I have the choice of both DSP and Mach3, I shooting towards DSP since its so easy to operate, but I am concerned about it failing after reading this thread.
  10. #10
    May 2012
    I have the same problem with the Richauto not wanting to starup.
    Please send me the files to reboot it.
    Thanks in advance
    Ronnie Shand
  11. #11
    Feb 2018
    Al
    My controller will not boot up either fo you have the file ? and instructions on how to boot it up ?
