Can you convert a 3 axis AKZ250 to 4 axis?
Results 1 to 6 of 6
Thread: Can you convert a 3 axis AKZ250 to 4 axis?
    Member Azalin's Avatar
    Mar 2014
    Turkey
    Default Can you convert a 3 axis AKZ250 to 4 axis?
    I have a 3 axis AKZ250 USB board (aka Leafboy card). On the right side of the board (see the yellow circle on the attached image) there is two optos missing. Looks like soldering there the right components will make it 4 axis however that's just my guessing. Has anyone tried this? Did/will it work?
    Thanks in advance.
    Best,
    Suat
    Attached Thumbnails Attached Thumbnails Can you convert a 3 axis AKZ250 to 4 axis?-akz-jpg
    Suat
    Proud father, C# developer, Model heli pilot, newbie free time machinist for hobby
    Member CitizenOfDreams's Avatar
    Nov 2012
    Default Re: Can you convert a 3 axis AKZ250 to 4 axis?
    It should work if the firmware is the same for 3-axis and 4-axis cards. But I suspect the 4th axis is disabled in the firmware.
    Mar 2014
    Turkey
    I guess you are right.
    Suat
    Oct 2005
    New Zealand
    Ive just soldered 2 new chips.. damn no action. how to get the firmware?
    Member lennardvn's Avatar
    Sep 2019
    did`t you ever get it to work ?? same issue here
    Mar 2014
    Turkey
    If you are asking me, sorry I've never tried.
    Sent from my MI 5s Plus using Tapatalk
    Suat
