Originally Posted by
petemilligan
I completed the Vital Integra upgrade. It's not too troublesome. Though a few gotchas. I'm running windows 10 with Mach4 presently.
Prior to this I was using ESS on Windows 10 with mach3. It's very workable & all was fine until one of the boards supplied with the Syil failed - hence the upgrade.
In summary - the upgrade required all boards in the Syil to be removed after labeling the wires. The front control display and buttons were replaced with a single steel plate (painted yellow obviously) with an e-stop button. Both relays were swapped out to be compatible with the Integra. A rotary encoder fitted to the spindle motor for threading.
If you need pointers then I'm very happy to help.
Pete
