Need Help! Help with Novusun NVEM USB control card - Page 3
Page 3 of 3 FirstFirst 123
Results 25 to 31 of 31
Thread: Help with Novusun NVEM USB control card
  1. #25
    Nov 2017
    Default Re: Help with Novusun NVEM USB control card
    Quote Originally Posted by JUGETEK-Rony View Post
    I brought a copy one at low price : Novusun NVEM USB control card
    It works well.
    Hi, thanks for sharing the detail which is more useful. Since im building a CNC machine as a first time Hobby work, im literally confused on the wiring, im planning to make two different type of 6 axis machine operation 1) Orientable-Spindle machine 2) Orientable-table Machine. based on the manual i have done teh wiring detail for all the component, Still im unable to conclude the wiring completion for VFD / Limit switch /E-Stop / MPG. and need the list of power supply on the same.
    here with im attaching the available circuit diagram, request you to cross verify and guide me for the further wiring, if there is nay correction required, plz let me know.
    6 axis NVUM control board.pdf
    https://drive.google.com/file/d/1slU...xN9zuPfswfRd0t
    Kindly do teh needful
  2. #26
    Nov 2017
    Quote Originally Posted by morg769 View Post
    Hello Socramor
    I will tell you I sent mine back. The A-axis would not step right and after a few lines of code it would tell me there was an USB ERROR and stop. I am going back to my old breakout board and a UC400ETH Motion Controller. But here is a rough wiring diagram of what I had. Hope it helps and if you need any other questions let me know. Rod
    Help with Novusun NVEM USB control card-nvem-wiring-diagram-jpg
    Dear Friend
    Since this is my first time machine build as my hobby work , Im totally confused and im unable to move further for the wiring connectivity keep struggling for months together.
    Circuit details are mentioned below:
    https://drive.google.com/file/d/1HUm...ew?usp=sharing
    https://drive.google.com/file/d/1qoT...ew?usp=sharing
    Considering on the above circuit details , Kindly give the answer / guide /solution for each of the below question:
    1) Im planning to operate the control board to make both the functional machine 1) orientable- Spindle machine 2) orientable - Table Machine { both the METHODOLOGY detail i have mentioned in the attached drawing } , is it possible operate in this method? Or needs to change any mentioned axis.
    2) OPTION-1 as a Orientable -Spindle Machine = X- Axis / Y- Axis / Z- Axis / A-Axis (as a 4th axis) / B-Axis (as a 5th axis ) and W-Axis (as a 6th axis) basically where spindle alone will take action of move (up & down) ( front & Back), in the position of spindle body dependence on the effect of A-Axis & B- Axis . in this case can i take a control terminal from C Axis? or there are some other options available ? or its not possible? For your better understanding im attaching a machine detail with considered axis.
    3) OPTION-2 as Orientable-Table Machine = X- Axis / Y- Axis / Z- Axis / B-Axis (as a 4th axis) / C-Axis (as a 5th axis ) . is it correct?
    4) For OUTX connection , What is the capacity of relay needs to use for this complete setup? plz provide me the product link its possible.
    5) What is the capacity of POTENTIOMETER needs to connect for this complete setup? plz provide me the product link its possible.
    6) MPG wiring connections are correct? ( MPG product link -
    https://www.aliexpress.com/item/NVMP...311.0.0.nfVxqg
    7) VFD wire connection is correct? if any thing needs to add or if some thing is wrong plz guide me how to connect.(simple hand sketch also fine) (product link -
    https://www.aliexpress.com/item/Free...608.0.0.moeUKz
    8) Im planning to make a physical HOMING & LIMIT SWITCH for the all 6 Axis ( X / Y / Z / A / B / C ) , in this case in manual there is one number of limit switch where shown, but im having 12 numbers , plz guide me how to connect? (simple hand sketch also fine)
    9) If im using PROXIMEY limit switch means, how i can connect for all 6 Axis ?
    10) In SPINDLE S-AXIS - ( INDEX ) Is this terminals not required to connect anywhere? If this terminals needs to have connection ? where to connect?
    11) In OUT PORT ( OUT-4 , OUT-6 , OUT-8 , OUT-10 , OUT-5 , OUT-7 , OUT-9 ) which and are all the terminals not required to connect anywhere? which and are all the terminals needs to have connection ? where to connect?
    12) In MPG ( 10X , E-STOP , B-IN , Z-IN , X-IN , 100X , 1X , C-IN , A-IN , Y-IN , GND ) which and are all the terminals not required to connect anywhere? which and are all the terminals needs to have connection ? where to connect?
    13) In 12-32Vin = shall we go a head with 36V power supply ? If you can able to give teh product link will be much helpful.
    14) Communication external interface terminal ( white plug with 4 connecting lead) where to connect? what its purpose? in manual also no detail available.
    15) In INPUT PORT - ( INP-3 , INP-4 , INP-5 , INP-6 , INP-7 , 12V , INP-8 , INP-9 , INP-10 , INP-11 , INP-12 , GND 1 ) which and are all the terminals not required to connect anywhere? which and are all the terminals needs to have connection ? where to connect?
    16) Kindly give the list of power supply unit for the complete set
    17) Can we use this Control board for the plasma cutting machine too?
    Request you to help me out to complete this project.
    Attached Files Attached Files
  3. #27
    Feb 2009
    Venezuela
    Hi my friend could you please send to me USB cable inclusive
    Program & manual by email.
  4. #28
    Feb 2009
    Venezuela
    Hi asuratman i have thos card, but i don´t know how to use , could you please help me...
  5. #29
    *Registered User* cncfoamshaper's Avatar
    Oct 2018
    I'm running the Version 2 of this Controller (see my video)
    Unless the controller is bad it sounds like a settings issue in the MACH3 setup.
    Follow the ports and pins setup from the Novsusun manual and you'll be ok. I have the A axis slaved to the y axis with the motor reversed. Works fine.
  6. #30
    Registered syntronik's Avatar
    Jul 2013
    Parma
    Default Problems with VSun R2 6 axis
    Anything is OK, i have only problems, the axis, do not go, example Z must be increas when go up, + direction, and - down direction, it's not possible, to reverse the
    signal direction, i set anything, also to invert the motor by hardware, when i push Z + in the jog it go up, but count down, and is not possible to change,
    what i can do??
    Maurizio Crescini
    www.syntcncsrl.com
  7. #31
    Registered DigitalDream's Avatar
    Oct 2018
    Go to Menu-Config-Port&Pins -- Motor Output on Mach3 sofware,you can change the Z axis direction.
    Huan Chen
    Digital Dream
    Digital Dream Automation Technology Co., Ltd.Digital Dream
