Pls see the attaching file.
it is the DLL file, if you use the dll file pls follow the configuration of EC500.
Because EC500 is updated from NVEM V2,they can share the same dll file.
Welcome more questions.
Digital Dream
Good evening,
I'm new here but I've been following this forum for some time. I would like someone to get me the latest dll for NVEM, so I can fix the softlimits problem
Digital Dream
Last edited by DigitalDream; 12-13-2018 at 07:44 AM. Reason: I typed wrong information
I use NVEM V1 (3pcs) and driver :
Product Version: 4.0.0.1
Original name: Novusun_V4.dll
I have problems with limit SW, Probe, Subs Call, M3 and M5 timing on my plasma cuter.
Any new driver or sugestion??
Tnx
Pero
Hello Huan Chen, I tried to send you a private message but they are diasbled for you.
I'd like to know more on your MPG LCD controller: NVMPG WITH LCD with serial connection (https://www.nvcnc.net/NVMPG1.jpg).
Which product is compatible with it??
Is there any documentation about serial communication to and from this device?
Thank you very much!!!!
Max
Hello members,
I purchased the V2 in hopes that the bugs could be sorted out but its just so poorly supported by the manufacturer. Its a shame they don't release the source code because the community could turn this product into something great. On a hardware level it seems to be pretty decent. The actual motion control portion and step accuracy is quite good but the drivers are just so buggy, ruining the overall usability of this controller.
here is a thread on the forum of what I believe is the original manufacturer. I posted some youtube videos with some of the bugs everyone seems to be having in hopes to gain some attention. Best of luck to the owners of this product.
NVEM V2 - Driver problems - PWM, Soft Limits, Incremental Jog - NVEMV2——Ethernet mach3 controller - Digital Dream Technology support
PWM Spindle "VSO" output - Slow Ramp Up
Incremental step jog latency/lag
Homing & Soft limits issues / Disconnect issues
Hello members,
Hi
I have got me a Novusun NVEM to. First I had also problems to connect on Windows 10. The only problem with thad was, Windows don't recognise the NVEM as a private network member, so Mach3 has to be allowd access to the public network.
Here is how I tested the controller.
I use NVEM v1 and have soft limit, slow zone and limit sw issues. havent these issues solved yet for anyone? i really need a new plugin for my cnc. please email me if a new plugin is available. (safa.dh@gmail.com)
thx
Today I try running NVEM V2 with EC500 plugins.
It's work great, Connection is very easy and fast.
The machine run smoothly but auto square using A axis slave to Y axis still not working.
Regards
hi milky could send me also the link for NVEM Driver _P (Released 23/05/2017)
hi miky could send me also the link for NVEM Driver _P (Released 23/05/2017)
Hello,
can someone send me the new driver with the fixes on Limit and Homing switches? NVEM Driver _P (Released 23/05/2017)
Thanks.
Hi! I also want to get the fixed version of the DLL for NVEM v1. Are there any plans from the developer to make these corrections or I can forget about it and do not longer communicate with the controllers of this company?
miky4u2
I am running a USB NVUM4-SP using Windows 10.
Could you please send me a copy of the latest .dll and/or driver?
Is the latest still the NVEM Driver _P (Released 23/05/2017)?
Thanks in advance
Hi everybody,
I have got (unfortunately) NVEM V2 ETH controller. Two days ago I tried to connect to it - with success. Motor Nema23 worked fine. But yesterday ma controller can't connect to ethernet.
Two diodes orange and green flash about 7-8 second and stop for 1 second. On PC I have connection for 7-8 second and after this time connection stops.
Has anybody the same situation with NVEM?
Thanks for any answer.
I also need help with NVEM V2 ETH controller.
It does not connect to my router. I have tried different LAN ethernet cables with no success.
And when I check the log of the router no request for an IP has been received.
Anyone had similar problems?
Thank you
