Anilam 1100 Controller Problem - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
Thread: Anilam 1100 Controller Problem
  1. #21
    Jan 2016
    Default Re: Anilam 1100 Controller Problem
    i just encountered the same problem,replaced the battery but lost all memory (i guess) cant get it to run again(when servos activate the table just goes in -y for about 3" then shuts down the servo)
    what settings did u have to reenter? did u use a floppy for the computer or the manual for the control with the password?
    steve.
  2. #22
    Jul 2012
    India
    Hello
    How did you solve the problem for your Anilam 1100 cnc control.
    i have similiar machine with the same problem like yours. Same errors. How did you fix that.
    Please send me the details
    Thanks in advance
  3. #23
    Hi could you give me the engineers contact in the uk , I’ve got issues will my mill had the cmos errors changed out the battery but now won’t boot , not to good with computers so need to get someone in ASAP
    thanks
    paul
  4. #24
    Jul 2012
    India
    Quote Originally Posted by Pauldhar View Post
    thanks
    paul
    Hi Pauldhar,
    Its Bouvier Jerry
    His email id is jbouvier@heidenhain.com
    But the problem is since they have put the 1100M controller into absolute and they are not providing the service for the same. They can give a upgrade for the same controller.
    In the meantime if you have time , please check the input supply in the cpu,check the cmos battery for 3.6 volts and the button cell for 3 volts..Check if there is any damage in the electronic components. Use a magnifying glass to check the components for any oxidation on the solder joints or burnouts.
    Thanks and regards
    Clide
  5. #25
    Thanks I managed to get a Cpu Card from a 3300 which does have a blue wire soldered to it , I have now managed to boot but I don’t know how to get it set up as I can start the servos now but they move 3” and switch off . We do have an autolube on it so I’ve read that I may need to check that but also we now have a separate power supply for the pc . I get dead stop switch reached and when I start servos I get error spindle or prog. Controller disable .
    not too good at this but getting there any more help would be appreciated
    paul
  6. #26
    Here is a link to the bios settings: http://www.illianaindtech.com/PartsB...NC-systems.htm
    Does anyone have the config settings?
  7. #27
    Hi blakey235 could you let m have the anilam engineers email in the uk please , I’ve tried the guy in the states but it just gets pinged back
    thanks
    paul
