Natedog. I hope it works out fine for you. Its not so hard to do. And you ll allways be able to pull the board back out and redo it. As long as you have the grafic card and the keyboard. Make sure to place a brand new battery in so you don t have to redo everything again. and while the board is out. pull out mempry chip clean it and reseat it in the same position as it was in. make picyures even if you are sure you know what you are doing. be carefull and always ground yourself before touching any pcbs on the machine.
Take care
