- China newker 1000 series servo gear ratio
Hi there
As seen in the photos, when I say go 1 mm, when it goes forward, it goes missing. How is the belt system calculation done? I did not fully understand the handbook you gave.
my Y axis
When 3mm goes, the bench goes 2.91mm.
When 2mm goes, the bench goes 1.92mm.
When 0.3mm goes, the bench goes 0.26mm.
My gear system:
Servo shaft: 24 tooth
ball screw input : 49 tooth
Ball screw pitch: 5 mm (1 turn)
Please check my gear parameter 1.jpg picture for y axis.I think,its is a wrong
I think my settings are wrong, can you calculate for me?
I am waiting for your reply.
Re: China newker 1000 series servo gear ratio
After the first move to -0.3 mm, the change in position equals the change in move. So the settings are OK.
You have backlash/play/tilt in your Z-axis resulting in about 0.08 mm backlash. Check the play in your guides, spindle nut, spindle bearing, flexible coupler, belt elasticity, belt / pulley mismatch. Even the indicator could suffer from backlash.
Mount a bolt on the large pulley, mount an indicator (magnetic holder) on the frame and move the pulley CW. zero the dial (ref position), move the pulley ccw a small step and thancw back to the reference position. It should be zero again. Repeat the procedure but now rotating the pully not a small step, but half a turn. It should be 0 again.
Repeat the steps above but now in the opposite direction. I guess, you will find the source of most of you problems.
- You may not post replies
- You may not edit your posts
Forum Rules
